Baffling Roof Leak
All building related posts in this forum please
ACL
Has thanked: 2 times
Baffling Roof Leak
Post by ACL »
So I've a stone terrace, c1900. Roof has been updated as it has a breathable membrane. I've had the chimney stack re-pointed and new lead flashing/soakers done. Im still getting water leaking into the loft down the wall where the chimney stack is, it drips from the sockets of both purlins. Only happens when I get heavy rain. It's dripping not just soaking through via osmosis.
Any ideas?
Has thanked: 831 times
Been thanked: 3628 times
Baffling Roof Leak
If possible I would carefully check the flashing above the leak points, it only needs a pinhole or crack to weep through. Do you have any chums with a drone, the cameras are very high definition, it might do the job.
ACL
Baffling Roof Leak
Post by ACL »
That's the baffling thing. the flashing is over a few months old. I had it re-done recently. new lead soakers as well.
Baffling Roof Leak
Roof work is always hard to inspect as you need to get up there. Try tracking in the roof with kitchen paper to spot ingress points, it might give you a clue.
ACL (Thu Jan 02, 2025 12:59 pm)
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Baffling Roof Leak
Post by London mike 61 »
You could put a chimney pot cowl on top of the chimney and that may solve the problem of water ingress , they are relatively inexpensive and you can fit it yourself if you have access to a ladder and nerves of steel !!
Mike
These users thanked the author London mike 61 for the post:
ACL (Fri Jan 03, 2025 9:50 am)
ACL
Baffling Roof Leak
Post by ACL »
sorry, should have mentioned all the chimneys have been capped and the flaunchings have been done.
fin
Has thanked: 32 times
Been thanked: 816 times
Baffling Roof Leak
Post by fin »
are the chimneys ventilated? its no good just simply capping them off they need ventilation still
are you sure the lead work has been done correctly? ive seen leadwork done by others that has been done badly and ive had to re do it.
ive even known actual roofers to make mistakes on it,
Return to “Building Forum”
