Ariston Andris water heater reset button
fender62
Has thanked: 3 times
Post by fender62 »
got an Ariston Andris undersink hot water heater, stopped working no red light unit does have power though, the reset button is stuck in, was working but... there is a push tap on the sink that was stuck in the down position and would not rise back up, so hot water continued to flow for erm hrs until discovered, so i can assume it burned out the unit ? thus the stuck reset button, iv turned off the power to the unit and waited thinking the reset would popback out for a reset.. nope, anything else i could try before getting a new unit.
ericmark
Has thanked: 118 times
Been thanked: 785 times
Post by ericmark »
I am sure the reset can be renewed, but would also need to renew the thermostat, I found the instructions on line, but they tell you very little.
fender62
Post by fender62 »
ericmark wrote: Thu Jan 09, 2025 5:02 pm I am sure the reset can be renewed, but would also need to renew the thermostat, I found the instructions on line, but they tell you very little.
thanks for reply, reaplcing both parts negates just buying a new unit i suppose.
ericmark
Post by ericmark »
I have an advantage, I have an insulation tester and a multi-meter so I can test and be sure before ordering parts, but it does seem likely replacing the thermostat and reset it will work, but can't guarantee anything without testing.
Return to “Electric Forum UK”
