Bedroom ceiling glistening near Soffit
leckyone
Has thanked: 7 times
Post by leckyone »
Some 20yrs ago we had extra insulation put down in the loft at 20cm deep (InstaFibre roll). 3 years ago we had 4 extra roof vents with ever increasing summer temperatures. At same time the felting around the soffit edges was replaced.
With the recent constant near freezing temperatures, notice in 2 bedrooms on the ceiling edge to the soffit to have a glisten effect.
The roof has 5 vents in total, would extra soffit vents help. The soffit is approx 16mts long by approx 40cm wide.
leckyone
Post by leckyone »
Think I’ve found of what may be causing the problem.
When the loft insulation was laid, they laid it up against the rafters/roof not allowing circulation down to the soffit ? 🤷🏻‍♂️
