Bathroom nightmare
NS34
Has thanked: 2 times
Bathroom nightmare
Post by NS34 »
We have had ongoing issues with the bathroom paint peeling off the ceiling and walls. I recently spent quite a bit of time redoing it all and 3 weeks after finishing the job, the paint cracked everywhere. I can’t make sense of it.
What I did:
Remove all the paint peeling off, sanded the edges, applied Zinsser peel stop, applied toutpret fine filler, applied zinsser bin, painted with Zinsser perma white. No use of the bathroom during the work and curing time were respected.
Any suggestions?
Has thanked: 831 times
Been thanked: 3627 times
Bathroom nightmare
It looks like a classic case of no mist coat on new plaster. Do you know the history of previous decoration?
NS34 (Wed Jan 08, 2025 10:15 pm)
NS34
Bathroom nightmare
Post by NS34 »
No, I don’t know what was done before unfortunately. What needs doing then? Start all over again?
NS34
Bathroom nightmare
Post by NS34 »
dewaltdisney wrote: Wed Jan 08, 2025 10:03 pm It looks like a classic case of no mist coat on new plaster. Do you know the history of previous decoration?
No, I don’t know the history and I don’t know what to do
Bathroom nightmare
I am not an expert but I think would be inclined to go over with a steam wallpaper stripper. My idea is that the steam and heat from the stripper may delaminate the poor substrate allowing you to scrape it back, paint that does not come off would be proved well fixed. At least then you can go from a sound surface.
NS34 (Wed Jan 08, 2025 10:46 pm)
NS34
Bathroom nightmare
Post by NS34 »
dewaltdisney wrote: Wed Jan 08, 2025 10:44 pm I am not an expert but I think would be inclined to go over with a steam wallpaper stripper. My idea is that the steam and heat from the stripper may delaminate the poor substrate allowing you to scrape it back, paint that does not come off would be proved well fixed. At least then you can go from a sound surface.
Ok, I see. Thanks
