Compressor suddenly stopped working - suggestions?
Posted: Thu Jan 16, 2025 5:56 pm
by pjontheroadagain
Could anyone suggest why my Airmaster Tiger 8/65 'Turbo' compressor has suddenly stopped working?
It was running fine but when I switched it on during the recent cold snap, it ran very slowly for a few seconds then stopped. I wondered if it was because the cold weather had made oil was too to turn over, but just tried it again now it's warmer but its dead.
I've checked the fuse in the plug and the electrical connections under the pressure switch/safety valve (which was replaced a couple of years ago) but can't find anything wrong.
Any suggestions of what else might be at fault?
Posted: Thu Jan 16, 2025 6:44 pm
by Someone-Else
I am just wondering has the pressure switch failed? I found a manual on line
Click me
Posted: Sat Jan 18, 2025 9:41 am
by pjontheroadagain
Thanks Someone Else
Yes, the new pressure switch was made in China, no doubt from chocolate, so I was going to try swapping it with the old one.
Thanks for the link to the manual.
Posted: Sat Jan 18, 2025 11:59 am
by Bob225
iirc it has a reset switch for the thermal overload - it's on the motor casing
highlighted in green
- airmaster 8-65.jpg (68.04 KiB) Viewed 272 times
Posted: Sun Jan 19, 2025 6:42 pm
by bourbon
try pushing the overload button back in. That's an old compressor, We changed the model number ages ago. All of the pressure switches for small compressors are made in China. Please don't delude yourself thinking otherwise. Are you running it off an extension lead by any chance? The thicker oil is certainly something to consider. First port of call is the reset switch though
Posted: Wed Feb 05, 2025 11:36 am
by pjontheroadagain
Thanks guys - yes, I tried resetting the overload button but to no avail. I did a continuity test on it, which seemed to suggest it was working.
A friend has sinced tested the capacitor for me and found it seemed to be OK, although apparently the test equipment used very low voltage - not sure if that's conclusive?
No, the compressor was plugged directly into the mains.
Posted: Wed Feb 05, 2025 6:59 pm
by Bob225
Can you turn it over by hand, I take it the oil level is ok
Posted: Mon Feb 10, 2025 12:02 pm
by pjontheroadagain
Yes, it turns over easily by hand and the oil level is fine. I think the fault lies with the electric motor - I'm hoping that it is either the starter capacitor or the overheat cut-out switch that is at fault but I'm not an expert on these matters!
