Mira Coda shower bar cartridge question
plumbing, drainage and waste water questions here please
juco
Has thanked: 3 times
Post by juco »
Had issue with shower bar, however was cheaper to replace with new shower bar.
Now I have taken the Mira off I thought to inspect it hoping to find what the issue was.
I am at the stage as per image how do I get the cartridges out, I didnt want to force anything til I got some advice.
It looks like one I have to undo the nut the other I don't see anything I can loosen to get it off.
Advice anyone.
Has thanked: 823 times
Been thanked: 3544 times
If you do a Google search for 'exploded view Mira Coda' and then select images you will see a number of diagrams you can have a look through to find your valve. It will give you a better idea of the disassembly method.
Return to “Plumbing Forum”
