Installing Kair MVHR help
azk404
Post by azk404 »
Hello
I want to install a Kair MVHR to help with humidity in the kitchen and want to run through a potential installation method please.
I have an inside dimmer switch (that can be changed to a permanently on module??) which leads to an outside junction box. Could I use that to power the fan and control box as per the diagram? I can also add a exterior fused spur between the junction box and fan/control unit.
Would that be acceptable?
https://www.kair.co.uk/product/kair-hea ... entilator/
Cheers
E
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
Do you have a neutral at the dimmer switch ?
What is the “control box” you refer to?
azk404
Post by azk404 »
The control box is a humidity sensor that controls the fan and ideally it shout be place further away from the fan.
Yes there is a N.
The far left module is the one that leads outside.
I believe the right dimmer module I actually already made hard power a while back as that goes to a 2-gang plug above the fridge.
Neelix
Post by Neelix »
I very much doubt the power for that lot comes from a socket circuit
azk404
Post by azk404 »
Ah thats not what I mean, that all comes from the mains box under the floor.
I have one of the modules powering a socket thats all.
Return to “Electric Forum UK”
