What is the best way to fill these and stop them reappearing?
Post by hiace_drifter »
hiace_drifter
moderator2
Thanks, I wonder if the gaps is too thin to get filler in (it's about half a mm, if that). Would it be worth raking it open to a couple of mm?dewaltdisney wrote: ↑Tue Jan 28, 2025 8:59 am It looks like a natural movement crack so I would gently rake the crack with the edge of a filling knife to remove any loose plaster. Fill with flexible filler wiping smooth as you go to minimise sanding back. Leave to dry out and then cover the filled areas with a dilute emulsion to seal it and minimise different absorption rates that could look patchy when you paint the wall.
hiace_drifter
hiace_drifter
stevei
