Help identifying marks/stains/damage on kitchen ceiling
I have some marks/stains/damage on my kitchen ceiling which I am trying to identify, I am hopeful that somebody in this forum may be able to give me some pointers.
I have limited experience with DIY and limited knowledge of building construction but will try to answer any questions you have to help clarify the issue.
The marks/stains/damage have been present for a number of years and haven't noticeably changed over time.
I am looking to replace the downlights in the kitchen but would first like to establish what repair work is needed on the ceiling, in case that needs to be prioritised.
I have attached various photos showing the issue.
I have included some additional detail below regarding the kitchen space if that helps to diagnose the problem.
I would gratefully hear any thoughts on what the issue could be caused by and what steps I should take to remedy the problem.
Thanks!
A description of the space:
The property is a victorian mid-terraced house, our kitchen is at the rear of the property.
Half of the kitchen occupies an original ground floor room with our bathroom occupying the room directly above it.
The other half of the kitchen occupies a single story rear extension, which roughly doubles the length of the original space.
The rear extension has a mono pitched roof which adjoins our neighbours property
Separating the original room and extension is a steel beam which indicates the position of the previous rear wall and protrudes roughly 20CM from the ceiling.
Our oven and sink are both located in the original space, not the extension. Mentioned as they would contribute to steam/grease being distributed around the room while in use.
The extension has a large fixed window at the rear which does not open, the original room has a window to the side which does open. This means air circulation in the extension is likely to be limited.
It is in that single story extension area of the kitchen, beyond the protruding steel beam, where we have identified marks/stains/damage on the ceiling.
Thanks!
- IMG_20250223_124758.jpg (72.15 KiB) Viewed 861 times
- IMG_20250223_124752.jpg (113.51 KiB) Viewed 861 times
- IMG_20250223_124741.jpg (95.35 KiB) Viewed 861 times
- IMG_20250223_124733.jpg (110.67 KiB) Viewed 861 times
- IMG_20250223_124723.jpg (98.76 KiB) Viewed 861 times
- IMG_20250223_124719.jpg (109.45 KiB) Viewed 861 times
- IMG_20250223_124703.jpg (82.39 KiB) Viewed 861 times
- IMG_20250223_124655.jpg (113.99 KiB) Viewed 861 times
