- It is currently Mon Mar 31, 2025 7:55 pm
3-gang converter socket
- Has thanked: 71 times
- Been thanked: 2 times
I have a 2-gang socket that is close to the corner of the room. I need an extra socket, so wondered if a 2 to 3-gang converter might work. Trouble is, I assume the converter socket will be symmetrical, in chich case, it will not fit. Do such things and Left-handed or Right-handed converters exist?
- RouterSockets.jpg (76.92 KiB) Viewed 1005 times
headey
- Someone-Else
- Has thanked: 48 times
- Been thanked: 2604 times
What does google show?
All the ones I have seen have the connections in the middle, so would not fit where you want.
Why not put another twin socket above or below the existing one?
- Has thanked: 120 times
- Been thanked: 1043 times
I have seen some that can be placed centrally or off to the left or the right.
The only problem with 3 gang sockets is they are usually fused to 13amp which is annoying given a standard 2 gang will be 26amp.
Rorschach
- Has thanked: 118 times
- Been thanked: 219 times
Neelix
- big-all
- Pro Carpenter
- Has thanked: 740 times
- Been thanked: 2355 times
i use these quite a lot plug in sockets switched and unswitched random link
https://www.ebay.co.uk/sch/i.html?_nkw= ... &_osacat=0
your router could still be plugged in where it is as no hard cable out the bottom
- Someone-Else
The majority of twin sockets are only rated for 13A
- s3.jpg (65.42 KiB) Viewed 990 times
- s2.jpg (57.96 KiB) Viewed 990 times
- s1.jpg (64.89 KiB) Viewed 990 times
They are only tested to 20A
- big-all
- Pro Carpenter
Plenty of people plug a kettle and toaster into a double socket and run it with no issues. There is no fuse so they are expecting you to pull up to 26amps. A 3 gang socket would not be able to handle kettle and toaster without blowing the fuse.Someone-Else wrote: ↑Fri Feb 28, 2025 5:06 pmThe majority of twin sockets are only rated for 13A
Rorschach
- Someone-Else
If what you say is true, (and it isn't) why are they all clearly labelled as 13A?
Thanks for all the advice. The hanging adaptor suggested by Big-All would be too big, but a 2 or 3-way might fit. As the new item is a Hive box, which uses a USB charger, the socket with a USB output might be an ideal option. Thanks for the tip.
headey
- big-all
- Pro Carpenter
incase its relevant
i have measured 3 plug in sockets and they are all between 100-110mm from the top surface off the earth pin to the bottom surface off the adaptor so finished about 2"/55mm below the actual socket level that would off course need a further say 25mm for moulded cord protector on thicker cables but not on wall plug in power sources
would something like this work ???
https://www.ebay.co.uk/itm/125006736000 ... K9SG4B7NG4
or this
https://www.ebay.co.uk/itm/286283309489 ... D9CNP0PBN7
or this
Arse covering. If they put anything other than 13amp on there people would start putting devices rated higher than 13amp in there.Someone-Else wrote: ↑Fri Feb 28, 2025 6:54 pmIf what you say is true, (and it isn't) why are they all clearly labelled as 13A?
BTW, the 13amp is on the back, the bit you can't see when you are using it. If you really could only put 13amp through, they would write it on the front very clearly.
Rorschach
- Approved Electrician
- Has thanked: 225 times
- Been thanked: 664 times
A 13A BS 1362 fuse will happily sit there and allow a kettle and toaster to run for hours. It will not even blow whilst the socket melts.Rorschach wrote: ↑Fri Feb 28, 2025 6:06 pmPlenty of people plug a kettle and toaster into a double socket and run it with no issues. There is no fuse so they are expecting you to pull up to 26amps. A 3 gang socket would not be able to handle kettle and toaster without blowing the fuse.Someone-Else wrote: ↑Fri Feb 28, 2025 5:06 pmThe majority of twin sockets are only rated for 13A
OnlyMe
And in the real world is the OP trying to draw more than 1 amp?Someone-Else wrote: ↑Fri Feb 28, 2025 5:06 pmThe majority of twin sockets are only rated for 13A
OnlyMe
I'll have to test this, I'd really like a 3 gang socket in my kitchen but have not done it because I will often need to pull more than 13amps from it.OnlyMe wrote: ↑Sun Mar 02, 2025 8:11 pmA 13A BS 1362 fuse will happily sit there and allow a kettle and toaster to run for hours. It will not even blow whilst the socket melts.Rorschach wrote: ↑Fri Feb 28, 2025 6:06 pmPlenty of people plug a kettle and toaster into a double socket and run it with no issues. There is no fuse so they are expecting you to pull up to 26amps. A 3 gang socket would not be able to handle kettle and toaster without blowing the fuse.Someone-Else wrote: ↑Fri Feb 28, 2025 5:06 pmThe majority of twin sockets are only rated for 13A
Rorschach
