Laminate Flooring
SadD3092
Laminate Flooring
Post by SadD3092 »
I'm interesting to know how did it worked out. I have similar situation as aeromech3's son. Two dogs(one of them is Frenchie), laminate in hallway, wooden flooring in bedrooms cowered with rugs. And I'm thinking about changing the flooring in the hallway cause when my dogs were pups, they tend to pee in hallway and now, in those areas, the surface is damaged. I have some spare laminate planks so I bought a saw to cut them and replace the damaged one. But I wonder if it worth it or maybe it worth to think about changing the whole floor?
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 570 times
Laminate Flooring
Post by moderator2 »
SadD3092, Best not to dig up an old thread. I've started a new one for you. Original thread here viewtopic.php?t=108046
Has thanked: 48 times
Been thanked: 2604 times
Laminate Flooring
SadD3092 wrote: Fri Mar 21, 2025 11:14 amI'm interesting to know how did it worked out.
Hi, the reason moderator2 split your question is because as is often the case on forums, the persons thread you jumped in on (JamieGates) only ever made 2 posts, and you just jumped on his 2nd post. In other words JamieGates was last here almost 2 years ago, so is most unlikely to read your question, let alone reply to it.
Return to “General DIY forum”
