Boiler pressure
Funkyboy
Has thanked: 1 time
Boiler pressure
Post by Funkyboy »
Hi All,
Is it normal to have to top boiler pressure up every 4mths by 0.2bar?
Has thanked: 831 times
Been thanked: 3627 times
Boiler pressure
It usually relates to the expansion vessel. In most boilers, it is a rubber bladder type with a car tyre-type valve. Over time the expansion vessel can take on water and this can lead to a pressure drop. Another cause is a drip from the pressure release valve that can let by in certain circumstances. Lastly, it could be a small leak that is so slow it is not evident. Start with pumping the expansion vessel and see how you go.
Funkyboy (Fri Mar 21, 2025 7:02 pm)
OnlineOnline
