- Ultimate Handyman Forum Index DIY Forum/Home improvement General DIY forum
- It is currently Mon Mar 31, 2025 5:17 am
Squeaky hinges.
- Has thanked: 120 times
- Been thanked: 1043 times
Squeaky hinges.
As part of the renovations I did last year I replaced all of the door hinges. The old ones were original to the property so pushing 50 years old, they were well worn with a lot play in them and rusting too.
New hinges are much nicer looking satin nickel, no wobble, nice and smooth. BUT, after a few months they squeak and creak. On the old hinges I used to use grease, but this was messy and ugly as it always oozes out and leaves a dirty smudge on the frame eventually. Any recommendations for something a bit cleaner and tidier? Some kind of dry lubricant would nice. I have used graphite powder in the past but expect this might be messy too, especially on white paintwork.
Rorschach
- Location: Worcestershire/Warwickshire/Gloucestershire (ish)
- Has thanked: 51 times
- Been thanked: 152 times
Squeaky hinges.
Hi.
I use WD40 Silicone lubricant.
https://www.screwfix.com/p/wd-40-silico ... 00ml/86394
Another option, which I haven't yet tried, would be Dry PTFE Lubricant.
Grumps
- Has thanked: 831 times
- Been thanked: 3626 times
Squeaky hinges.
Over the years I have used different lubricants on my door hinges including 3 in 1 oil and WD40. It is a rare occurrence for a squeak on my doors so I tend to grab what is nearest to hand and use that. I squirt it on the hinges, waft the door a couple of times and then wipe off with a bit of tissue. That PTFE spray is dry and might be a good bet.
- Has thanked: 20 times
- Been thanked: 13 times
Graeme from Tod
- Has thanked: 32 times
- Been thanked: 816 times
Squeaky hinges.
if your hinges arent in a straight line or atlest more or less in a straight line it could be why theyre squeaking
fin
Squeaky hinges.
They probably aren't, but I'm not refitting them
The old ones didn't squeak, but like I said, they had best part of 50 years wear in them, there was several mm of up/down movement in the hinges!
Rorschach
- big-all
- Pro Carpenter
- Has thanked: 740 times
- Been thanked: 2355 times
Squeaky hinges.
with squeaky hinges
90% off the time it's easy to stop the squeak and at the same time find the exact position the door was when the hinges where fitted
often the door will spring back to or resist movement away from that position
Squeaky hinges.
Smooth movement and no noticeable resistance, but if you let them swing as opposed to purposely moving them they make great horror film noises.
Rorschach
Squeaky hinges.
That can only be metal on metal noise resonating through the frame. I would suggest that the hinge pin is binding and grabbing, causing the squeak. I would try 3 in 1 oil, you can often get a small spray can in Poundland, and spray the hinge and waft the door to spread the oil. Wipe down excess and it should be good.
- Rorschach (Sat Mar 29, 2025 11:57 am)
