SDS Core Drill Bits
Posted: Fri Jul 11, 2008 7:49 pm
by Hoovie
I should know this, but just can't suss it out :oops:
I have a set of Silverline Core Drill Bits for an SDS Drill and I just cannot work out how the Auger is securely fitted to the Core :roll:
Is there a standard way this works or does it depend on the make? Need a photo of the kit in question?
Posted: Fri Jul 11, 2008 8:05 pm
by Hitch
I just googled for a pic of a silverline set, looks like the guide bit is fitted into the sds shank/arbour on a taper?
If thats the case, just push it in and give it a tap. :thumbright:
Taper drills are widely used in engineering.
Posted: Fri Jul 11, 2008 8:27 pm
by Hoovie
Yup - it is on a taper - I pushed it in but never gave it an extra knock - and then when I started the drill, it just spun off :roll:
I will give that a try tomorrow.
Cheers Hitch :thumbright:
Posted: Fri Jul 11, 2008 8:41 pm
by Hitch
I dont think you see this fittment for masonary bits much nowadays, i think ts was called k-taper.
They can be a pain to get aprt once well hammered in there. Should be a drift in the set i expect, a wedge eshape that you hammer through to push the bit out.
