The lid on my soft close toilet seat has stopped working (i.e. it just slams down like a regular lid). Does anyone know if it can be adjusted please? The seat itself is still working fine (closes slowly).
Cheers
Soft close toilet seat problem
- Been thanked: 1 time
I have a simular problem except on ours, the seat slams down but the lid is OK
Being replaced under warranty !
On ours if you look where the hinge shaft goes into the round body of the mechanism, a sticky gel is weeping from the seal, which I guess is the compound which retards the fall of the seat and lid.
If yours is the same type then replacement is the only option!
Retirement is an Illusion
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
If it is still under guarantee I would take it back. I don't think they are adjustable ( I know that the girlfriends is not adjustable ).
They are a bit of a gimmick to be honest and are ok, but they get you into the habbit of just letting go of the seat, which can land you in a lot of trouble in other peoples houses when it just drops!
