Source for birch-faced plywood
- Mooncat
- Has thanked: 81 times
- Been thanked: 72 times
I want to convert a 15 pane glazed internal door to plywood panels, Can anyone suggest a supplier of birch or similar light coloured ply in 3-4mm or 6-9mm. I can either use two pieces of the thinner ply togetger or a single of the thick as long as it is good both sides, as I want to varnish the ply to match the hemlock door. A single 8' x 4' sheet would be more than enough, or I could use off-cuts perhaps from a furniture maker. Pieces are 187mm x 332mm.
- Mooncat
The 3 I've asked only have the thick shuttering ply, or the far-eastern redwood(plundered rainforest). But I'll have to ask around a wider area next week.owen wrote:i think birch ply is widely available from decent timber merchants
I might have to consider fixing a piece of opaque material on her side of the door, and leaving it glazed
- Has thanked: 823 times
- Been thanked: 3562 times
Give this firm a ring http://www.severnply.com/news/newsitem.php?id=73
They will give you a local firm who can supply you. I order through my local timber yard. Cabinet grade birch faced ply is around £40 a sheet.
i am suprised at that, my local merchant stocks it and they have a pretty limited range.Mooncat wrote:The 3 I've asked only have the thick shuttering ply, or the far-eastern redwood(plundered rainforest). But I'll have to ask around a wider area next week.owen wrote:i think birch ply is widely available from decent timber merchants
whereabouts in wales are you? if you are near swansea, Gower Timber should either stock it or be able to get it for you.
