awkward stairs for a banister - help please
Roperd
Post by Roperd »
Hello, we've just bought our first house and know very little about DIY. I want to replace the very dated banister/handrail on our stairs with the usual spindle type ones but the problem is that our stair well is narrow and the side where you would put the base rail doesn't run all the way up the stairs but sort of disappears into the downstairs ceiling/upper floors (hope that makes sense). I have seen pictures of where the spindles go up as usual but then get shorter and shorter also going into the ceiling but I have no idea how to do this. Could anyone tell me how to do this safely as I can't see how i can make it sturdy
Tryanything
Been thanked: 4 times
Post by Tryanything »
Can you post a picture of existing handrail and spindles as it makes it so much easier for someone trying to give you advice
These users thanked the author Tryanything for the post:
Gun7h3r
There would be less trouble in the world
if l had not had six daughters
fin
Has thanked: 32 times
Been thanked: 808 times
Post by fin »
there is a type of handrail kit that is available with iirc hinged joints at end of the hand rails etc. dead modern lookin like. cant remember the name though. if i go to my local timber place tomoz ill let ya know
Roperd
Post by Roperd »
Yeah i apreciate my description wasn't very clear! I'll give it a go;
hope those work[/url]
Roperd
Post by Roperd »
Wow, they came out a bit big! Sorry about that!!
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
This looks like a tricky one :scratch:
I'm concerned about the handrail as well as there is not much room for it, because of the landing :scratch:
joiner_uk
Been thanked: 6 times
Post by joiner_uk »
A little bit tricky but will look ok when it is done.
diminishing spindles.jpg (47.33 KiB) Viewed 9052 times
Has thanked: 738 times
Been thanked: 2346 times
yep exactly as joiner says you have no real choice as the handrail has to be central to the string :wink:
you can also use a bit off string cap to top off the shortend spindles instead of handrail
also if the spindles are identical top and bottom you use the off cuts from the bottom of the "V" to fill in the top
Roperd
Post by Roperd »
Thank you all for your help so far - that picture is exactly what i had in mind! I can't see how it is done though - what is it that the spindles are going into as the bit that hangs down from the upper floor, the string, in ours is very thin? Is it just like another base rail with the spindles superglued in and is this secure esp if you cut them of mind way like it ? How is the hand rail fixed into the ceiling properly too?
oh and i meant to say, thanks fin, did you find the name of what you were talking about?
Thanks again
Roperd
Post by Roperd »
I apologise for my extreme lack of knowledge of technical terms too! :-)
look here http://www.stairpartsonline.co.uk/catlist.php?cat=2
choose "base rail" to see how you fit the spindles into the slots in the base rail and hand rail with spacers to keep them correct even distance appart :thumbright:
Roperd
Post by Roperd »
Thanks big-all - I think I now get how to slot the spindles in for the majority of them but what I am struggling to understand is how to get the top halfs in on the section after the handrail runs out and they start to go into the ceiling? I can't see what they are going into? Is it just a base rail attached upside down to the ceiling or is there a special thing you can buy? or do you attach the handrail horizontally to the ceilng for them to go into?
Sorry for all the questions
jp
Post by jp »
looking at the pic supplied with turned spindles in white, might be easier to use square or a stop chamfered type.
also if your going to modernise and want something great try axxys. it's spindles are tube round so easy to keep a pattern,
try www.cheshiremouldings.co.uk
Griffin
Post by Griffin »
Where the handrail meets the ceiling you would normally use more handrail against the ceiling so the moulding matches where the angle changes from diagonal to horizontal.
keeping in mind the hand rail also has a slot for the spindles to for into
you can as griffin says carry on with the handrail level with the ceiling using the spacers up to the cut round edge and filled in you will have to remove the shaped top surface of the handrail to sit properly on the ceiling or use string cap[base rail] that is already flat
what you do depends on your skills and what looks right in situ
