I need to remove a plastic push-fit joint. Obviously these joints are pushed to fit but are they just pulled to remove? Also can they be re-used once removed?
Any advice appreciated
Removing plastic push-fit fittings
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Most push fit joints can easily be removed, but each make is slightly different to remove.
here is how to remove the pipe from john guest speedfit-
Some of these have a plastic locking collet which will need removing, other newer models twist to unlock!
The hep20 ones unscrew-
These have a stainless steel grip ring that often can't be removed without damaging it!
The john guest ones are easy and can easily be reused.
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
Hi Oggy,
They can be removed, but it get's a bit complicated?
SpeedFit ones can have a split ring that was added to 'lock' the fitting, if this is the one you'll see it, remove the split ring and ....
hep20 ones have a twist lock mechanism twist to lock and twist to unlock and...
to remove you have to push the extended part 'SpeedFit', it's an inner sleeve you'll see protruding from the fitting, it should move in and out, it's loose.
If it's pulled out (like in fitting the spilt ring) it's locked, if you push it in it wedges between the teeth of the fitting and the pipe releasing it.
Can be really fiddly as you have to push and pull at the same time!
There is a release aid SPEEDFIT
Hep20
Hep20
Jaeger.
- ultimatehandyman
- Site Admin
- Gas/Heating Expert
- Been thanked: 9 times
