Tile trim - size
Xantiaman
Tile trim - size
Post by Xantiaman »
In hoping that this question doesn't sound too daft when you read it, I propose to use HomeLux tile trim around the edges of a window reveal, and the tiles are 6.5 mm thick.
Do I use 6mm tile trim and have a slight 'edge' to the tile, or go for the 9mm tile trim with a thicker layer of adhesive towards the edge where the tile meets the trim?
Thanks for any answers offered.
Regards,
Xantiaman
Honi soit qui mali pense
Telmay
Been thanked: 2 times
Post by Telmay »
Go for the 9mm trim as you also have your bed of adhesive.
"Where would we be without rules?
France! And where would we be with too many rules? Germany!"
Xantiaman
Post by Xantiaman »
Thanks for confirming my thoughts Telmay - appreciated.
Xantiaman
Telmay
Post by Telmay »
No probs :thumbright:
Only-Me
Been thanked: 3 times
Post by Only-Me »
:withstupid: :thumbright:
Tryanything
Been thanked: 4 times
Post by Tryanything »
Personally i would go for the 6mm bead as most tiles have a slight round
on the face edge anyway
If you use the larger bead you will end up with a 4mm adhesive bed at least
There would be less trouble in the world
if l had not had six daughters
Only-Me
Post by Only-Me »
Tryanything wrote:Personally i would go for the 6mm bead as most tiles have a slight round
:scratch:
Tryanything
Sorry should maybe have said trim instead of bead
This should explain it better
tile trim.jpg (20.85 KiB) Viewed 26388 times
Xantiaman
Post by Xantiaman »
Like the diagram - and see your point!
Only-Me
Post by Only-Me »
No...........it does'nt look good with a biscuit edge of tile showing.
9mm all the way :thumbright:
Tryanything
Only-Me wrote:No...........it does'nt look good with a biscuit edge of tile showing.
:scratch:
Mooncat
Has thanked: 81 times
Been thanked: 72 times
Post by Mooncat »
The 6mm size reveals the edge of CUT tiles. So the 9mm will have to do. What is needed is a wider choice of sizes to cope with the range of tile thicknesses. I don't like the idea of using a soft plastic trim with hard tiles. but they don't make make the proper round edged tiles like they used to.
Only-Me
Post by Only-Me »
There is a 7mm trim available.
God knows where........not from my supplier :scratch:
Telmay
Post by Telmay »
7mm now that would be too handy a size, so no wonder you cant get it!
Return to “Tiling Forum”
