how do i replace worktops without breaking the tiles
Posted: Sun Sep 21, 2008 11:42 pm
by grahamadgo
hi i want to replace my worktops whilst keeping the existing tiling. I have a u shaped kitchen.
i am ok with fitting the new one, ive done that before but could do with some tips on how to remove the old one whilst minimising the risk of breaking the existing tiles
any tips would be appreciated
thanks
g
Posted: Mon Sep 22, 2008 8:17 am
by ultimatehandyman
The worktop will be fastened from underneath, so remove all screws.
Where the worktop is jointed ther should be some clamping bolts, which clamp the worktops together, these are normally rebated into the worktop, these will also need removing.
Once you have done that you should be able to slide the worktop out from under the tiles, but if the tiler did not leave a gap then it may be difficult to remove and so be careful. You may have to lift the front edge of the worktop upwards to release it, so take your time and keep an eye on the tiles.
Posted: Mon Sep 22, 2008 8:24 am
by Hoovie
be worthwhile running a sharp blade along under the bottom edge of the tiles where they butt onto the worktop to free any connection between the two - in case the silicon joint between tile and worktop is stronger then bond between tile and wall
Posted: Mon Sep 22, 2008 4:09 pm
by marc1106
take off the plinths andadjust the rear legs of the cabinet so they are just "off the floor" this will also make it easier to slide new tops in.
When done just adjust legs back down again! easy peasy
Posted: Mon Sep 22, 2008 5:34 pm
by Tryanything
marc1106 wrote:take off the plinths andadjust the rear legs of the cabinet so they are just "off the floor" this will also make it easier to slide new tops in.
I'm with that
Posted: Sun Oct 26, 2008 3:34 pm
by Griffin
Assuming of course that you have adjustable feet on your units and not floor to worktop cheeks!
