Best woodscrews
Best woodscrews
Hi
Can anyone recommend a good make of wood screw, I have tried several different types of brass screw but they are difficult to drive in and often need a pilot hole.
Cheers rocco
Cheers rocco
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Hi Rocco,
I normally use turbogold screws or
turbo ultra screws if outside.
These screws are great and don't normally need a pilot hole or counter sink.
Last edited by ultimatehandyman on Mon Sep 24, 2007 10:43 pm, edited 2 times in total.
- Pro Cabinetmaker
Best we can get round here are Spax. They have a serrated leading edge to the threads and "glide" into MFC (melamine faced chipboard), etc. Just about the only "wood" screw I know which can join soft plastics, like polyethylene, WITHOUT balling. They do up to 6in long screws and they also offer Torx heads - great for security work. Only downside ois they cost twice as much as cheapies. Yers pays yer money.....
Scrit
Scrit
Measure twice, cut once - except fingers!
- Pro Cabinetmaker
I don't know if turbogolds are the same - I though that Spax held patents on their stuff. Spax can be had in BZP (bright zinc plated) as well as s/steel in some sizes, but it's the Torx option that makes it difficult for the scallies - they've yet to figure what that is round here!
Scrit
Scrit
- ultimatehandyman
- Site Admin
Not sure about this one!Scrit wrote:I don't know if turbogolds are the same - I though that Spax held patents on their stuff. Spax can be had in BZP (bright zinc plated) as well as s/steel in some sizes, but it's the Torx option that makes it difficult for the scallies - they've yet to figure what that is round here!
Scrit
Judging by the price that screwfix sell the turbogold screws at I doub't they are made by spax. Both are great screws though!
Hard to imagine using old wood screws now, pilot holes are often a thing of the past (thankfully).
Last edited by ultimatehandyman on Tue Oct 16, 2007 1:48 pm, edited 1 time in total.
I used come stainless steel screws from screwfix, I think they are called turbo ultra's or something.
They were used to fasten a wooden gate to a fence post, I tried to adjust the gate today and had to remove all of the screws but every single screw head sheared off!
Have I done something wrong or is this a common problem?
Cheers Rocco
Cheers Rocco
- ultimatehandyman
- Site Admin
- Pro Cabinetmaker
Rocco
Did you treat the stainless screws as you would treat brass ones - i.e. pilot drill, run in a bright steel screw 80% of the way, back-it out then screw-in your stainless screw? Brass screws can shear in hardwoods if you don't do this and s/steel are the same
Scrit
Scrit
- ultimatehandyman
- Site Admin
Hi Scrit,
I didn't, I just used them as I would use the turbogold screws- self piloting and self countersinking!
I have just seen in the new screwfix catalogue that it now says " A pilot hole may be needed", I am sure it never used to say that!
Next time I will take your advice!
UHM
UHM
