Stairs
54aardvark
Has thanked: 16 times
Been thanked: 56 times
Stairs
Post by 54aardvark »
Putting in a new handrail & spindles for a client, bit concerned about the height of the existing bannister on the landing, seems a bit on the low side.
I know it comes under building regs/H&S and I used to have the figures, but can anyone confirm the current (Scotland if it makes any difference)Regs for:
Minimum height of the handrail to floor.
Minimum spacing for the spindles.
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
In England the following applies;
900mm for handrail height
Spacing such that a 100m ball can not pass through.
In Scotland I think it is between 840mm to 1000mm for handrail and the same 100mm for spacing.
Hope this helps, you could 'google' for it.
John
Mr Mike
Been thanked: 1 time
Post by Mr Mike »
http://www.planningportal.gov.uk/englan ... 00536.html
Approved Document K available from Planning Portal website above.....
54aardvark
Thanks for that.
Those measurements certainly ring a bell - best to make sure though. And he will need another 75mm on his landing bannister height.
