Lights Out
Locked
Kabous
Has thanked: 7 times
Been thanked: 3 times
Lights Out
Post by Kabous »
Come on lads help solve this one.
Background
New build housse (2 years) - loop system used.
Outside light/ security light (those that switch on when movement is detected) blew a 40w bulb.
Bulb replaced but all other lights downstairs off. Easy, check distribution board for circuit breaker trip - NO trip.
Removed c/b and swopped with upstairs one. Upstairs lights still work. Downstairs with 'new' c/b NOT. So obviously not a faulty c/b.
Check all downstairs light bulbs all fine.
Any suggestions?
Hinton Heating
Gas/Heating Expert
Been thanked: 9 times
Post by Hinton Heating »
sound like its time to blow the dust from the electrical mutimeter, and do some live & neutral testing.
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Something similar happened a while back-
viewtopic.php?t=1016
Read the post by sparkydude :wink:
markysparky
Electrician
Contact:
Post by markysparky »
Was has happened is that you have had a bad connections and when the circuit blew it disturbed the loose wire meaning tripping all the lights in the circuit out.
Open the consumer unit and check for loose connections to the mcb and neutral of the circuit in question. If none there then if possible, try and follow the cable to the 1st light on that circuit and check that ceiling rose again for loose connections.
More than likely one or the other as you have no lights working at all.
Locked
Return to “Lighting”
