Fire proof door fitting
Can anyone give me a rough price for supply and fitting a fire proof door for a house? I need to have 8 put into a house but am completely unsure of what price I should be paying. I live in North Wales so no London price
Cheers
Also - what is involved in them being fitted? New door casings needed?
Cheers
- joiner_uk
- Been thanked: 6 times
Say you have a standard door size of 30" wide.
The fire door frames will be slightly wider than the original frames as they are a thicker section of timber to allow for larger rebaits. If there is not enough space at the side of the old frames (if they are tight to the brick work) this will cause problems
Perko door closers will be ok but check first, regs change every other week
The doors or frames need to be fitted with intumiscent strips to the top and sides.
The frames need to be sealed with fire retarded sealer
Get the frame fitted and seal frame, hang door, fit intumiscent strips if not already fitted to frame then fit architraves and latches, handles etc...
I would think for the fitting you will pay around £110-£190 per door and frame.
- carhartt kid
- Has thanked: 3 times
- Been thanked: 1 time
You don't have to replace the linings with rebated ones. All you have to do is remove and replace the door stops with 35x35mm stops. Glued and screwed! As opposed to nailed or pinned! That is however all depending on how standard the dimensions of the lined opening are, and how plumb and square! Fire rated doors have very very low tolerances for adjustment, ie planing the edges off. They all have hardwood capping's on their edges, covering a dense woodchip conglomerate inside! Often they only have enough for just a leading edge to be planed! Literally mm!!!
You'll also have to fit either smoke or intumescent strips to the door or lining. The difference will be dictated by the use of the room and its contents. ie Kitchen containing a cooker will have intumescent, whereas a bedroom will only be smoke strip! Fitting to the door is easier, as you just rout a channel for the strips! If you are forced to replace the linings, then a rebated lining is handy but not essential. A standard planed softwood lining is acceptable (and cheaper).
Closers, latches and hinges are the most important part of a fire door. The door is useless unless it is closed. And when hit by fire, that it stays closed and doesn't drop out from the hinges melting! I've done the course to "rate fire doors" and the demo they do where they burn through a selection of doors is startling! The hinges and ironmongery literally just melt.
For domestic or rented properties, concealed closers are rated, plus you have to have rated latches and handles. Plus (ball) bearing hinges (or architectural hinges as they are sometimes known) are a requirement!
Your local council planning office will have a a full list of what their requirements are. Plus you local fire service provide fire inspections and advice!
I used to do a lot of work for letting agencies and there was one thing that a lot of landlords overlooked at their great expense. Its all very well putting a fire door into a partition (stud) wall. But if the wall isn't clad in fire rated plasterboard or have fireproof insulation it makes the door only a minimal defence against the fore spreading. Even holes through the walls for waste pipes or electrical conduits have to be "firestopped" with intumescent collars or mastic!
A lot of this however will be dictated by the age of your property and the intended use. Be honest to the authorities and then you won't get stung later. Best of luck
http://www.carhartt.com/
- carhartt kid
- carhartt kid
