Aquapanel - Fixing
Rapier503
Aquapanel - Fixing
Post by Rapier503 »
In another post BathStyle said "If you go ahead with the Aquapanel then this needs to be stuck to the wall using rapidset tile adhesive and as said plugged and screwed in after which can be done two to three hours later."
Can I use Aquapanel (like you can plaster board) and fix it to a stud wall wooden frame or is than not the way I should do it? I have no wall to stick it too unless I stick it onto other plaster board.
Thanks in Advance
Rapier
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Yes it is designed to be screwed to a frame using their special ceramic screws-
dot-dab-aquapanel-direct-bond-aquapanel-t3056.html
Rapier503
Post by Rapier503 »
Thanks for the information!
Return to “Tiling Forum”
