Burnt/Cracked Kitchen Worktop
Posted: Sun Oct 26, 2008 4:58 pm
by chris 82
Hi all, any help is well recieved.
I seem to have left the old iron sitting danger side down on the kitchen top. In my defence i was jetlagged & i had a man cold, and i am also a berk.
The top is laminate, and now has a raised & a bit cracked manky iron shape to it. A friend swears i can get a replacement patch job from my local diy store, but searching the internet i cant see anything like it.
Is he talking crazy or do such things exist?
Posted: Sun Oct 26, 2008 5:36 pm
by big-all
you are in trouble
proper repair new worktop
as the top will be uneven and probably bubbled now you will have a job to stop any stray water
your choices are
hide it with a chopping board or simmilar sitting on the bubbles and rocking about
same chopping board seated on coloured silicone to support and stop water getting under the edge
router out the surface layer and use somthing contrasting like metal or glass siliconed in
Posted: Sun Oct 26, 2008 6:52 pm
by thescruff
Or smooth or all down and tile it
Posted: Sun Oct 26, 2008 8:37 pm
by chris 82
thanks guys. accidents happen, but that doesnt stop them being any less annoying.
the blistered bit is far away from the sink so im not too worried about water getting in. but it would be nice to have it smoothed and sealed. might go have a look in the shops tomorrow for anything that could possibly work.
erugh.
Posted: Sun Oct 26, 2008 10:50 pm
by handyman
cheers bigall,
If its ok I'm going to steal your idea, and put it to a customer of mine as my own
2 burn marks each side of the cooker, and a nice dark blue glass tile routered in might just do the trick
Posted: Sun Oct 26, 2008 11:00 pm
by Gadget
And finally, you could also renew all of the worktop!..
Posted: Sun Oct 26, 2008 11:23 pm
by Only-Me
Move House
Posted: Sun Oct 26, 2008 11:58 pm
by big-all
cheers bigall,
just remember if you need to do 2 or more passes make the depth off the first is the same as a bit off 5.5-6mm ply /mdf so if nesisesy you can pad out the rebate to support the base off the router as you cross the rebate
then give the same consideration to a second if you need to do a third pass
also before you chisel out the corners drill a hole with a drill 1mm bigger radius than the corner off the tile
if it has no noticable radius just use a 5mm drill bit
Posted: Mon Oct 27, 2008 8:24 am
by handyman
cheers big all,
will practice it on a bit of scrap worktop first (if she wants to go ahead)
Posted: Mon Oct 27, 2008 11:22 am
by big-all
handyman wrote:cheers big all,
dont waste a new cutter on your practice as it will blunt it quickly
what size are your actual tiles and what size is the router base!!!
