wooden internal step
bgatty68
Has thanked: 21 times
Been thanked: 5 times
Post by bgatty68 »
we have an opening in hall way of double doors and the wife would like a big wooden step-over from the hall to the next room, now can i just use a plain bit of timber and sink it into the floor or should i use a particular type of wood (would like it stained after) :scratch:
Has thanked: 736 times
Been thanked: 2341 times
are you describing a single tread on a stair or some sort of barrier :scratch: :scratch:
if its a small normal step any 18mm+wood will do
you could try your local wood yard for somthing exotic to make a featurre of it
fin
Has thanked: 32 times
Been thanked: 807 times
Post by fin »
i think he means something say 6 inch wide for example rebated so it will sit low down on the floor as like a thresh strip
bgatty68
Post by bgatty68 »
fin has got it, couldnt think of the correct wording :oops: , its for the thresh. Rather than having what most have a aluminium strip between rooms wanted something a bit more fancy :thumbright:
peter c
Has thanked: 6 times
Been thanked: 16 times
Post by peter c »
My house has hardwood thresholds to all rooms. They are oak about 12mm thick. Some where french polished but Mrs C requested! that I used paint stripper to return them to their natural state. Well pleased with the results.
Peter C
The end justifies the means
fin
Post by fin »
well i guess it depends what type of flooring you have. in my grandparents old house we laid laminate flooring right through the down stairs. but there was a difference in height between hallway and the kitchen. i got a piece of i think 4x1 dressed pine and rebated both sides to the relevant depths. then took the corners off with a block plane and it did the job just nicely. i screwed it down after counter sinking the holes and pluged them. then it was just varnished iirc as the flooring was a light colour beech iirc (beech or beach?? lol i cant remember)
