I'm about to install some oak skirting and a new oak internal door. I want to keep the natural look of the oak and bring out the grain - what best to use - Danish oil ?
Whats the best way to attach skirting to the wall, glue or nail/screw baring in mind this isn't going to be painted
On a connected point, putting up the skirting might bring out the fact that my plastered walls are not that level . Is there a product that I can use to fill in the gap between the plaster and the skirting that will blend in with the natural oak. I'm not expecting huge gaps
Oak Skirting and Door
- Pigglet
- Has thanked: 8 times
- Been thanked: 8 times
Re Finishing: What about Osmo polywax? I've used this on doors and other bits to give a nice durable finish
http://www.bona1stopshop.co.uk/acatalog ... eaner.html
I've just finished fitting some pine skirting and used no more nails applied ina wavy patern to the back of it. I pushed it onto the wall then brad nailed it to the studs behind the plasterboard to pull it into the wall. There were a few gaps along the top so I ran a bead of caulk along it.
- Has thanked: 823 times
- Been thanked: 3563 times
- Has thanked: 32 times
- Been thanked: 807 times
ive never fitted anything but pine skirting. however if that was to get stained id drill, counter sink and plug the holes. I should imagine this would be possible?
trend do a range of counter sinks and plug cutters in their snappy range
also is it in an old house? i fitted new skirtings in my house that had been made up to the same profile as the original skirtings. (victorian type house)
when i did this i coppied how it had been done originally with timber plugs between the bricks. though obviously i had to make up new plugs as the old ones had broken up over the years
