ali wrote:
Thanks.
I know I'm very probably being thick here.......but are you all talking about the same thing?
Big-all.....nicad,
nmhi
Hoovie....
Hi-MH
Are the nicad the first 2.4 ones????? Or are they both nicad but different 'strengths' (female technical term there
Are the
nmhi/Hi-MH/Ni-MH in all your posts, all the same things or different?
Ni-MH is the correct name and stands for "Nickel-Metal Hydride" - the others (inc mine) are typos.
Ni-Cad is "Nickel-Cadmium".
Ni-Cad is an old rechargable battery technology.
ali wrote:
If they are all the same, judging by Hoovie's post, I'd be better with the kit with the 2 x 2.6's? Or have I got that wrong?
Sorry, mental block today.
Ni-MH is a much superior option then Ni-Cads (Nickel-Cadmium) and if the XRP is a Ni-Cad battery, then the 2.6 Ni-MH set will be a better buy (assuming it is not way more money!)
the 3rd battery type I mentioned is appearing in power tools are Li-on (Lithium-Ion), also referred to as just Lithium (unless the two are subtle variations of the same thing?)
These are the new kids on the block, and provide features such as much greater power for the same battery physical size and a more rapid recharging.
The Li-on battery is also the ONLY way to effectively eliminate the Memory Effect - both Ni-Cad and NI-MH suffer from the memory effect, but Ni-MH is less pronounced.
Li-on are intelligent batteries that do not suffer from this generally BUT very often, they can only be charged a number of times before they will refuse to charge again (talking in the many hundreds here though)
