plasterer by trade but am undertaking my own bathroom renovation (apart from the plumbing)
Am swapping the bath around as to free up space to to fit all the units i would like, now my question is...
Wall where the new taps & shower fitting are to go are just plain 12mm plasterboard, should this be replaced by aquapanel
Also have had some water get in behind the existing tiles that are going to be ripped out, if the plasterboard has any water damage on should this also be replaced by aquapanel
All comments appreciated
Bathroom question
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
- ultimatehandyman
- Site Admin
If it is in an area prone to wetting, like above a bath where you have an over the bath shower, or in an area that has previously been effected by wetting then I would use aquapanel.mouth wrote:Cheers geez
Was a new house 7 years ago & for some reason they stopped short of tilling the whole bath/shower wall leaving a splash zone for anyone having a shower over 5'8
You'd use aquapanel even though the wall is going to be tiled totally?
It is especially important if you are using mosaic tiles or small tiles as there are more gaps between the tiles for the water to soak into.
