I have a fairly wonky kitchen and dining room floor currently
I have two sunken areas where the joists have gone and areas where a thin sheet of board on top of the floor boards is missing.
I can repair the joists, what i need to establish is how to get the floor nice a level all over!!
What i intend to do is remove the current vinyl flooring and lay a fresh new vinyl. The current surface is knackered as the missing board has caused indentations.
What i appear to have is a very thin gauge board covering the original floor boards. would it be overkill to rip the lot up and relay from fresh?
I want the floor to be as smooth and level as possible as im bored of saggy corners and damaged vinyl!!
how to level a floor!!
