lifting floor boards
Hello, and thanks for any advise that may be forthcoming..
I have the complete groundfloor of my 1930's semi to lift and clean and then those that don't have too much woodworm to re-lay.
I wonder if you could offer any advice?
Firstly, getting the things up easily, as this is proving to be more of a problem than i thought...!
- Has thanked: 7 times
- Been thanked: 51 times
how-to-post-photo-s-t9415.html
If they are nailed in the middle of the boards then you should be able to lift the nails without breaking the edges. Use a handy bar to get under the nail head and then prise them proud with a pair of pincers. Then you can get a wrecking bar or a claw hammer onto the nails to get them out.
Phil
Advise rhymes with rise. Advice rhymes with rice.
- Tryanything
- Been thanked: 4 times
With T&G boards you have to remove the fixing first as Geewizz has said
Not the easiest of jobs without the right tool
1930s property, boards will probably bee fixed with floor brads or cut nails
What your going to need is a nail puller, the one in the picture is top of
the range but there are cheaper models about
- 33963.jpg (40.93 KiB) Viewed 2841 times
There would be less trouble in the world
if l had not had six daughters
- Tryanything
Geewizz l can pull 3" screws with that babyGeewizz wrote:I use fencing pliers but I suggested pincers as something more commonly found in a toolbox.
I like the look of that grappling iron you posted there, Tryanything. I must get myself one of those even if it's just for show.
I think considering the number of nails involved a nail puller would be 10
times quicker than any other method
Oh, I agree. I didn't mean to cast doubt on your choice of tool or a challenge to it, though I cn see how my post could be interpreted that way. The two paragraphs were supposed to be read quite seperately. I meant that the nail puller looked quite gruesome and would make a good addition to my tool collection for its aesthetic appeal. let alone its pulling power.
Phil
- Tryanything
- Gadget
- Jack Of All Trades
- Has thanked: 344 times
- Been thanked: 342 times
In my youth I used to wear Old Spice for 'pulling power'Geewizz wrote:Oh, I agree. I didn't mean to cast doubt on your choice of tool or a challenge to it, though I cn see how my post could be interpreted that way. The two paragraphs were supposed to be read quite seperately. I meant that the nail puller looked quite gruesome and would make a good addition to my tool collection for its aesthetic appeal. let alone its pulling power.
By eck! ©
