How to create a lift-up and sliding-door?
I want to create something that has a door that works in a similar manner to this:
Closed:
Open:
As you can hopefully see from the pictures the front/door can be lifted up and slides into the top of the cabinet. I wondered if there are any specific hinges/runners that do this job - any links to UK suppliers would be ideal.
Thanks in advance for your help.
-D
Closed:
Open:
-D
- Tryanything
- Been thanked: 4 times
This site looks like it is for trade only, I've sent an email enquiry about placing an order. I've looked elsewhere but can't find the same thing anywhere else I don't suppose you know of anywhere else (the only alternatives I can find are for doors and would not work for flaps like this one).
EDIT: Forget that, found them here: http://www.bkservicesonline.co.uk/shop/ ... ts_id=8472
- Tryanything
- Tryanything
Here's another type that may be better suited for your intended application
http://www.sdslondon.co.uk/product/8051 ... 400mm.html
There would be less trouble in the world
if l had not had six daughters
