help! beech block worktop colour match
We have moved into a rented property where there is a burn mark in the solid wood worktop. I have also accidently put a pan on the worktop for a second and it has burnt it in another spot, i sanded the areas down and put a clear varnish on it but the colour doent match and the varnish stands out shinny against the rest of the work top, i was hoping that i wouldnt have to sand the entire worktop back. Im sure the worktop is varnished, any advise would be appreciated. I am having trouble uploading pictures on the forum.
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
- carhartt kid
- Has thanked: 3 times
- Been thanked: 1 time
Hey Surfchick35
As its a Beech Block worktop, i'd agree with Geewizz and say its probably oiled!
I'd sand the patched back again and tray adding a few drops of darker varnish to the varnish you're using. A little pot should only be a few pounds! Or, get a oil that matches and just keep adding a little more till the depth of colour matches. To get rid of the shine, you can give it a little rub with some new wire wool. Really fine grade stuff!
Anyways, if you're really a surf chick, cool, and welcome to the forum. Its dead handy!!! Surf wise, charts look sick for the week ahead. Forget the worktop and go get wet instead! Monday on is gonna be pumpin!!! Just hope Weds hold up to the predictions!!!
Mahalo... CC
Mahalo... CC
http://www.carhartt.com/
- Tryanything
- Been thanked: 4 times
The finish on woodblock worktops in normally Danish Oil
You will have to remove the varnish that you have put on
Sand the areas down with a 120 grit paper to remove the varnish and any other marks
Apply a good coat of Danish Oil to the sanded areas
When dry you will notice that the grain has raised where the Danish Oil has been applied
Lightly sand the areas down again with 180 grit paper and apply another coat of Danish Oil
At this stage l would suggest that you lightly sand the whole worktop and give it another coat of Danish Oi,
There would be less trouble in the world
if l had not had six daughters
