The wife
Grumpy people only in here please
The Weegie
Has thanked: 7 times
Been thanked: 21 times
The wife
Post by The Weegie »
Why does she never listen ::b ::b
I am putting a handrail on the landing wall.
So says to the wife that due to the wall being plasterboard, I would put a batten onto the wall and then attach the handrail to the batten.
NO WAY she says. I am not having a big piece of wood running down my wall :cussing:
When I explained that due to the strain and pressure on the handrail the fixings will probably not hold.
Her response. Oh honey I have every faith in your skills. :shock: :shock: :angryfire: :angryfire: :angryfire:
She will just not listen :angryfire: :angryfire: :cb
So people should I stick to my guns and put the wood on the wall or take the chance and use these handrail supports on fixings.
http://www.screwfix.com/prods/42644/Iro ... 5mm-Chrome
It may seem difficult at first! But everything is difficult at first.
IDontBelieveIt
Been thanked: 1 time
Post by IDontBelieveIt »
Stick to your guns!!
No doubt about it YOU are right and SHE is wrong!
Give way and you will regret it all your life.
And if you do as she says and when it (not if) falls off the wall with her holding it (the rail Weegie, pay attention) it will be your entire fault.
Women have a remarkable aptitude for forgetting what they don’t want to remember
Old Gits Know Best ... I think
gib_goblin
Been thanked: 8 times
Post by gib_goblin »
That won't hold on PB for very long, the first person to slip & grab the handrail will almost certainly loosen it.
Are you able to secure through the PB to the battons behind it with longer screws?
....or another trick I tried once with curtain rails on plaster:
- For each screw, drill an oversize hole in the Plasterboard
- Then fill the void between the Plasterboard & wall with pollyfilla (may need something stronger for the handrail)!
- Once it's dry, drill into the wall through the pollyfilla and then just rawlplug & fix as normal (make sure you get a fix into the wall not just the filla)
- You won't see the oversize holes when the brackets are fitted.
Don't buy a dwarf with learning difficulties,
It's not big and it's not clever.
Steve the Gas
Been thanked: 33 times
Post by Steve the Gas »
Good call :thumbright:
uropachild
Post by uropachild »
Can't you recess the wood bit into the wall so you can't see it?
Sarah
[img]http://i14.photobucket.com/albums/a334/Uropachild/IMG_5753i.jpg[/img] [img]http://i14.photobucket.com/albums/a334/Uropachild/IMG_5693i.jpg[/img]
feva
Has thanked: 14 times
Been thanked: 49 times
Post by feva »
i would bit it on how she wants then after a coupke of days when your coming down the stairs pull it off then spend 3 days doing the i tols you so bit!!!!!!!
such is life!
The Weegie
Thanks for the reply guys.
Gib Goblin. The oversize holes is a good idea. I might just try that if she doesn't budge. What about using expanding foam in the void??
Uropachild. I think the wife would come at me with a knife if I suggested that. It was re- plastered only 2 days ago. :lol:
uropachild
Oh, right. :lol: Well, a bit o smoothing over and sanding and no one need ever know! :wink:
Sarah
Tryanything
Been thanked: 4 times
Post by Tryanything »
You could be looking at a life threatening accident if the hand rail is not fixed properly
You need to find the vertical timbers in the stud wall to achieve a good fixing
Use a stud finder or small drill bit and drill a horizontal row of holes till you find the centre of a timber
Once you find one timber the others will probably be at 400mm centres
And doing it this way you can keep OH happy unless you want to kill
her/him then just fix it to the plasterboard :lol:
There would be less trouble in the world
if l had not had six daughters
Handy Angie
Pink Admin
Post by Handy Angie »
I have shoes racks on plasterboard walls and by god do they take some weight. Hollow wall fixings - you can swing on them. Thats the way to do it!
Tryanything
Handy Angie wrote:I have shoes racks on plasterboard walls and by god do they take some weight. Hollow wall fixings - you can swing on them. Thats the way to do it!
"Rubbish" and anyway what are you up to trying to swing off the walls
gib_goblin
The Weegie wrote: Gib Goblin. The oversize holes is a good idea. I might just try that if she doesn't budge. What about using expanding foam in the void??
I wouldn't recomment expanded foam, the idea with polyfilla is to provide a solid packing to give you a secure fitting raised from the wall / flush with the plasterboard. The foam would crush under pressure then you'd get movement and eventually failure.
Maybe fill the plaster void with a little mortar or cut a giant wooden dowel the same diameter as the bracket, same depth as the void & PB for fixing?
The Weegie
Gib Goblin you are right about the expanding foam :oops:
I know that the right way is to find the studs, but you try and tell my wife that you are going to drill small holes in a newly palstered wall. Not a good idea.
I decided to use these plugs
http://www.tooled-up.com/ManProduct.asp?PID=7347
knowing that over time they will not hold.
However the wife will not believe me until it comes away from the wall. So watch this space.
It will come away one night when I am pis..d and try and grab hold of it before I fall :-)
bobbie-dazzler
Has thanked: 54 times
Been thanked: 87 times
Post by bobbie-dazzler »
feva wrote:i would bit it on how she wants then after a coupke of days when your coming down the stairs pull it off then spend 3 days doing the i tols you so bit!!!!!!!
Funny enough Feva, I agree with you. :lol:
I would rather want something I dont have, that have something I dont want
Tryanything
Now l know why Scotsmen wear skirts because the women are wearing there trousers :lol:
Locked
Return to “The Grumpy corner”
