- It is currently Tue Apr 15, 2025 12:40 am
black spots
black spots
hi all.im new to the forum and it looks impressive,lots of helpful tips.i have a problem in my newly built bungalow of only 3 yrs.since we moved in there is blacky grey spots(patches)coming in the ceilings of the bedrooms and living room and kitchen.its like a fungus or a mould or something.the walls are fine maybe apart from an inch down from the ceiling where the spots slighty appear also.has any of ye come across anything like this or know what it is or better still,know of any cure?thanks in advance.
maurice.
maurice.
mm1
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Post by ultimatehandyman »
Hi and welcome to uhm.
Is it possible to post some pictures of the problem?
It does sound like mould, which can often be caused by poor ventillation in the rooms.
I doubt it is a damp problem as the house is so new, unless it was built by some dodgy workmen.
- ultimatehandyman
- Site Admin
Gadget
thanks for the replys lads.got the photos on.the photos are not very clear as recently i cleaned the ceiling and the blacking process is only coming back again.see what ye think anyhow.
- PC270659.JPG (81.18 KiB) Viewed 3110 times
- PC270660.JPG (79.63 KiB) Viewed 3110 times
- PC270661.JPG (71.71 KiB) Viewed 3110 times
mm1
- Welsh Decorator
- Been thanked: 4 times
- Contact:
Post by Welsh Decorator »
Looks like typical condensation to me, any ideas as to how much insulation there is over the ceilings?
I wish I was born rich..............instead of just good looking!!!
Welsh Decorator
there is insulation over the ceiling but i woundnt
say the builder used a roll too much if you know what i mean.there is the odd spot where i can see the slab board in the attic,just the odd spot.would the condensation come down the walls a slight bit also as the spots come maybe an inch or two down from the ceiling on the walls?
maurice.
maurice.
mm1
- Welsh Decorator
- Contact:
Sounds like my house at the minute, odd walls I've got condesation 6ft up!
There is one way to slow it down, and that is to raise the temp of the ceiling and walls, in other words make then more thermally effective.
Very thick paper ect, or improve the ventilation, or like me, get a good dessicant dehumidifier.
Welsh Decorator
- ultimatehandyman
- Site Admin
Is there any ventillation in the room?
Do the windows get condensation on them?
not much ventilation.the windows get opened a bit now and again.no vents on the walls.yes,condensation does come on the windows during the night in the kids rooms.in me and wifes room there is alot of condensation some mornings,more mornings there would be none,is this normal?
Condensation does depend on several factors.
You could do with either increasing the ventilation in the rooms, or get a dehumidifier.
Ventillation is the best option as dehumidifiers can dry the house out too much and give you a sore throat, although I have one and use it fairly regularly.
mm1
mm1
- ultimatehandyman
- Site Admin
My fault,mm1 wrote:dont know how the last 4 lines of my last post got there as i know nothing about hummidifiers.
Looks like I hit the edit button instead of the quote button and so it looks like you posted it
These are my reply-
mm1
- ultimatehandyman
- Site Admin
Double glazed windows are not as bad as single glazed windows, but it still happens in lots of cases.mm1 wrote:dont worry bout it.i was starting to think i was going mad..is condensation on the windows a bad sign or is it just because of bad ventilation?i thought the new double glazed windows should never condensate.
In a lot of new houses now they actually put vents in the windows, so that you can ventilate the room.
Are there any chimneys in the rooms, that are no longer used?
You can often use a disused chimney as a vent, provided the chimney is not capped off outside.
mm1
