tiling onto chipboard a no no i guess
sparkydude
Has thanked: 2 times
Been thanked: 149 times
Post by sparkydude »
After reading the above topic, if i remove my chipboard flooring, would i be able to replace it with 18mm WBP insteaqd of 25mm? just wondered as the cost between the two is astronomical, and just hope that 18mm will be ok.
Cheers
Nick
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
What tiles are you fitting, man made or natural stone?
sparkydude
Pretty sure they will be porcelain, or ceramic, not natural stone for sure.The chipboard is shot anyways so got to come out .
Nick
Tryanything
Been thanked: 4 times
Post by Tryanything »
If joists are at 400m centres 18mm should be ok screwed every 200mm
and fit noggings between joists where ply edge's join so as to eliminate
any movement
There would be less trouble in the world
if l had not had six daughters
Return to “Tiling Forum”
