estimating hardwood
xoxjt86
estimating hardwood
Post by xoxjt86 »
i'm planning a few ambitious hardwood projects, the first hurdle's got me really! ::b
is there an easy way to work out the amount needed for an exterior door? (or any job for that matter)! not used to workin in cubic ft!!
Has thanked: 736 times
Been thanked: 2341 times
draw your full sized rod[plan]
if you are buying preplaned order the stock size you want and add 20 to 30% [to cover spares as below]
if you are working your own timber just send/take your cutting list to the wood yard and sort it out from there making shure you have enough extra to cover an extra style and the biggest rail plus any panels
dont forget to allow for the horns and tennons in your cutting list
Tryanything
Been thanked: 4 times
Post by Tryanything »
Multiply the width by the thickness and by the lengh in inch's of the
timbers required and then divide it by 1728 to give you the quantity in
cubic feet
Example
6'-6" x 2'-6" x 2" door with
2 no 4" x 2" styles = 13'-0"= 156" x 4" x 2" = cubic inch's 1248
1 no 4" x 2" head = 2'-6"= 30" X 4" X 2" = cubic inch's 240
1 no 8" x 2" bottom rail = 2'-6"= 30" X 8" X 2" = cubic inch's 480
1 no 8" x 2" middle rail = 2'-6"= 30" X 8" X 2" = cubic inch's 480
Total 2448
Divide by 1728 which is cubic inch's in a cubic foot
2448 divided by 1728 = 1.416 cubic feet
CUBIC FOOT.jpg (28.46 KiB) Viewed 1286 times
There would be less trouble in the world
if l had not had six daughters
xoxjt86
Post by xoxjt86 »
thanks fellas!! this site is great, only now ive got no excuses for doin the work when she asks!!
Tryanything
Try here if you get stuck for one :lol:
http://www.excuses.co.uk/
