New dimmer switch went pop
criptonite
Post by criptonite »
Errr, connected a new dimmer switch for my living room light. I tested it before screwing the plate full on and it was fine. When I screwed it tight and turned the power on, it went pop. Have opened it up and cant see any exposed wires. Literally in the dark now.
The wiring was three core and earth with the yellow unattached on the previous light switch
tim'll fix it
Been thanked: 1 time
Post by tim'll fix it »
you must have connected live and neutral
what went bang the switch or the fuse/breaker
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
It sounds like a wire has been trapped.
dimmers are much deeper than switches and so you may need a deeper back box fitting.
has the fuse blown for the circuit ?
criptonite
It was the switch that went bang. I think there's enough room but I will check again. Thanks
criptonite
Oh, and the fuse hadn't blown
tim'll fix it
so are all the other lights working
could be a dud switch
Is it a two way light switch?
I'm wondering whay 3 core has been used, but the yellow is not connected?
criptonite
All the other light switches are fine. Could I have got the live and neutral the wrong way round? I was a bit confused by the three core cable
criptonite
By two way, do you mean that it controls two lights?
How many wires are there and what colours are they?
criptonite
Its red, blue, yellow and earth. The yellow was trimmed back and unconnected to the old dimmer switch
criptonite
Just read a bit more, the dimmer is two way, I assume, because it has an L! and L2 terminal
criptonite wrote:By two way, do you mean that it controls two lights?
Yes can you switch the same light on from two seperate switches?
You would need the yellow wire to make it work on a two way system.
Go to the other light switch and remove the screws, you should see a twin core and earth, the wires from this will be in L1 and L2
The three core and earth will be in common, L1 and L2
write down which colour wire is in which terminal, for example-
common- yellow
L1- Red
L2- Blue
Now go back to your dimmer and copy this exactly, so that you mimic the other light switch. So at the dimmer you will also have-
common- yellow
L1- Red
L2- Blue
criptonite
There is another switch on the opposite wall but it doesn't do anything. Must've been a 2 way switch in the past
Locked
Return to “Lighting”
