Getting a single floor tile up without breaking any others?
mpooley
Post by mpooley »
Hi
I have some mixed size ceramic floor tiles and i need to get one or two of them up. They are not cracked and are pretty thick ,
is there a technique for getting them up please?
Mike :help:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
I'm afraid you will have to break them to get them up!
Drill them in the centre and then score them and break them out from the hole in the centre using a hammer and chisel/strong screwdriver.
Here is how to drill them-
http://www.ultimatehandyman.co.uk/tilin ... _tiles.htm
Tryanything
Been thanked: 4 times
Post by Tryanything »
As the good advice from UHM but in addition if you can, grind out the
grout joint with a thin diamond blade around the tile, which cuts down the
chance of damage to the next tile
I use a 2mm wet stone blade in a small angle grinder for this type of job
There would be less trouble in the world
if l had not had six daughters
mpooley
Post by mpooley »
Thanks very much :-P
I thought id have to break them just wasnt sure of the best way.
Ta :thumbright:
Tryanything wrote:As the good advice from UHM but in addition if you can, grind out the
That is a good point :wink:
The Bosch PMF 180E would also be good for that, with the correct tile cutting blade.
Return to “Tiling Forum”
