Pin holes after grouting
Posted: Mon Jan 26, 2009 5:37 pm
by juandan
I tiled my bathroom, today I started grouting the tiles I had a 2.5 space between the tiles I was using Unibond waterproof grout, everything seemed to go ok, after about 2 hours I went back into the bathroom to admire my work, but to my surprise I noticed a few pin holes between the tiles and little cracks, I've gone over the cracks and pin holes with more grout, have I done something wrong for the grout to crack and for pin holes to appear
Posted: Mon Jan 26, 2009 5:55 pm
by marc1106
unibond addy/grout is infamous for shrinking back!
did you use the little plastic speader they give you or a grout float? you can hit it again with a grout float and press hard into the joint and it should be ok after a second hit! (but might need 3rd)
Posted: Mon Jan 26, 2009 6:28 pm
by jozeffo
Did you mix with too much water?
I prefer Mapei grout to unibond as it has more plasticisers in it which make it stronger. Screwfix and several tile shops sell it and the instructions on the packet are very precise about the amount of water to use. I also use a proper grout float and work the grout in thoroughly to ensure that it goes the full depth.
Posted: Mon Jan 26, 2009 6:46 pm
by juandan
I didn't mix any water with it, you buy it ready mixed, I used a grout float, do I have wait for it to dry before giving it another coat
Posted: Mon Jan 26, 2009 7:02 pm
by ultimatehandyman
Ready mixed grout is never a good idea. I remember trying that stuff years ago and it was crap!
Posted: Mon Jan 26, 2009 7:11 pm
by jozeffo
Annoying that the products which often look like they will be easiest to use and therefore appeal to the DIY market are often absolute rubbish. Adhesive and grout, readymix plaster, readymix filler etc. Are the manufacturers trying to put people off DIY?
Posted: Mon Jan 26, 2009 7:13 pm
by marc1106
jozeffo wrote:Annoying that the products which often look like they will be easiest to use and therefore appeal to the DIY market are often absolute rubbish. Adhesive and grout, readymix plaster, readymix filler etc. Are the manufacturers trying to put people off DIY?
I HOPE SO
Posted: Mon Jan 26, 2009 7:15 pm
by marc1106
i WOULD wait for it to dry RAKE a little out then hit it again! really work it in well and you should be ok this time!
Posted: Mon Jan 26, 2009 7:18 pm
by ultimatehandyman
A lot of these products are absolute pants. The combined adhesive and grout is total crap and it should be illegal to sell it!
Posted: Mon Jan 26, 2009 7:34 pm
by marc1106
ultimatehandyman wrote:jozeffo wrote:Annoying that the products which often look like they will be easiest to use and therefore appeal to the DIY market are often absolute rubbish. Adhesive and grout, readymix plaster, readymix filler etc. Are the manufacturers trying to put people off DIY?
totally agree with you, but seeing as OP has already started with it he may aswell persiveer, BUT next time get a PROPER addy and sperate (powdered) grout!
Posted: Mon Jan 26, 2009 7:35 pm
by marc1106
oo er what happened there
