Hi
I need some assistance with lighting in my garage.
It is a double length garage converted to a single garage and workshop, a panel construction separates the two with door access.
The two light units have a switch at each end of the garage enabling the lights to be turned on at one and off at the other.
My question is I need some guidance how I can convert each light to be controlled by its own switch.
The reason for this being if I am working in the workshop for hours on end the other light is on as well, therefore creating a waste.
Many Thanks
Moved to electrical forum
Ozzy
- Ultimate Handyman Forum Index DIY Forum/Home improvement Electric Forum UK Lighting
- It is currently Fri Apr 11, 2025 7:43 pm
2 Way Light Switching Conversion
stalbansherts
- Gas/Heating Expert
- Been thanked: 9 times
Post by Hinton Heating »
Do you still want to be able to control both lights from either end, or use one of each of the exsisting switches for each light?
Hinton Heating
- Electrician
- Contact:
Post by markysparky »
Not as straight forward as you may think!
If you could explain or post some photos then we might be able to help you better.
markysparky
Post by stalbansherts »
Many thanks for your replyHinton Heating wrote:Do you still want to be able to control both lights from either end, or use one of each of the exsisting switches for each light?
Either really, whichever might be the most straightforward.
stalbansherts
Many thanks for your reply.markysparky wrote:Not as straight forward as you may think!
At the moment as you enter the garage from either end there is a light switch located at the entrance, whichever one is used turns on both lights, this is how it was set up when the house was built.
My preference would be to be able to enter from either side and switch the light on for that particular area rather than both lights coming on.
If I am using the workshop for any length of time the other light is on just wasting energy.
I am uncertain if it complicates the issue even more, the other thought crossed my mind as to if the current setup could be retained and individual switching be used as well when necessary?
stalbansherts
- sparkydude
- Has thanked: 2 times
- Been thanked: 149 times
Post by sparkydude »
As Markysparky said, can you post a photo or a diagram of what your current set up is, cable numbers , cores etc, then we will definiteley be able to help you out, but as there are so many varied ways of wiring lighting its hard to advise without knowing what setup you currently have.
Nick
Nick
sparkydude
