Letter box flap ripped off
- steve_gb
some would be burgalar ripped off my letter box flap on a upvc door now it will sit in the groove but there are no plastic nibs to keep it in as they were broke off...any ideas?? thought about silicone but too light...is there a plastic weld type of solution???
- big-all
- Pro Carpenter
- Has thanked: 736 times
- Been thanked: 2341 times
is the flap metal or plastic!!!
how thick is it !!!
my thought are to use somthing like pannel pins into tight drilled holes and glued in if enough "meat"
or a sutable bit off wire glued full length and through the holes
or see if you can source a new flap!!
how thick is it !!!
- big-all
- Pro Carpenter
