Black and Decker circular saw type 1 ks55
Mick Coleman
Has thanked: 2 times
Post by Mick Coleman »
Hi
I have a Black and Decker circular saw type 1 ks55
16mm bore
Could anyone tell me a good circular saw blade for it.
I want one that will cut doors and leave a nice finish on both sides of the doors i cut.
PAINTER 1
Has thanked: 740 times
Been thanked: 2355 times
what size is the blade kerk [2.1!!!] what diameter blade!!!
in general the more teeth the better but with doors your better to score along the cut line on top and the end with a stanley knife
i use freid pro blades
Mick Coleman
i ant got a clue whats that (blade kerk)
170 mm diameter
PAINTER 1
Mick Coleman
score
Should i only have to score one side
i take it its the side the blade will come out as the cut underneath should be good
PAINTER 1
sorry that should be kerf lol the blade thickness
yes exactly right because the teeth are pushing into the leading edge and curving up into the wood underneath the dammage comes as the teeth exit the top and front edge as theres nowt to support wood and stop the splintering
if its an expensive door or melamane board you can do one pass at 1 to 2mm then another full depth plus 2mm although you wil still need to score the front edge with a stanly knife :thumbright:
Mick Coleman
ok
ok thanks just got to find a good blade now
PAINTER 1
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
I can only find one on ebay that will fit it- dead link removed
There seems to be more with a larger bore, which will require reducing bushes, and also a lot of slightly larger blades.
Mick Coleman
link
thanks i know what im looking for now
PAINTER 1
Return to “Tool Talk”
