What would you do with this?
BRUNO
Has thanked: 34 times
Been thanked: 67 times
Post by BRUNO »
Hi all,
In my bathroom there's a boxed in riser in the corner, plasterboard and timber. After taking a hammer and chisel to the tiles it's in a right mess. I want to tile over it and am wondering how should I go about fixing all the little holes and tears .
Should I reskim ? The tiles I'm putting on are heavy enough porcelain
ones.
Thanks!
BRUNO
Post by BRUNO »
pics!
plasterboard 002 (Small).jpg (31.77 KiB) Viewed 1398 times
plasterboard 001 (Small) (Small).jpg (21.73 KiB) Viewed 1398 times
leebwk
Has thanked: 3 times
Been thanked: 31 times
Post by leebwk »
If it's it's just the boxing i would remove the old p/board or material and replace with new, much easier than trying to mess about with it
BRUNO
Post by BRUNO »
That's what I'll do- thanks Leebwk
manchestertiling
Post by manchestertiling »
Either that Bruno or get some BAL Quickset Render to level it up & tile direct to it, set in 2 hrs so don't need to wait like you do if plastering.
http://www.bal-adhesives.co.uk/products/quickset-render
:thumbright:
Paul
[url=http://www.manchestertiling.co.uk]manchester tiling[/url]
m3 fitter
Tiling Expert
Has thanked: 7 times
Been thanked: 14 times
Post by m3 fitter »
replace the plasterboard to the boxing, fast and easy....remember to use a mechanical fix adhesive, powder mix single part with porc.bond for porcelain, not bucket ready mix.
Return to “Tiling Forum”
