behind the extractor fan or not?
- Has thanked: 1 time
hi,
I'm doing a splashback in the kitchen, got a few issues:
I've got 0.8" gap between the extractor fan and previous tile. I was thinking, cut a slightly bigger side to go behind the extractor fan?
Also i've got external mitre cuts to do, but when using my tile cutting saw (from wickes), the edges are getting chipped? is it better to trims?
The tile are black, ceramic, 10x10.
Also should i tile behind the pipes? see picture for more info
- 13032009.jpg (81.61 KiB) Viewed 2662 times
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Not sure about the extractor without seeing a picture.
I'd not tile behind the pipes though, it will be a major pain in the arse to do so and then the pipes will still be seen.
You could make a removable box though-
http://www.ultimatehandyman.co.uk/boxing_in/index.htm
- manchestertiling
Agree with UHM, will look very ugly still for all your effort of tiling behind the pipes. On boilers we usually box in the pipework & build an access door with a magnet closer, silicone the hidden hinges side & closing side, wait to cure then slice with a scalpel, hard to see the cut once closed again. You can get silicone to match grout colours now.
External mitres are difficult unless you have a very good thin diamond blade, we use a 0.8mm diamond kerf blade.
Extractor fan - Do you mean from your last full row of tiles upto the bottom of the extractor? If so then diamond blade again, will cut thin slithers if needed.
Paul
[url=http://www.manchestertiling.co.uk]manchester tiling[/url]
thanks for your replies, will look to box it in.
The extractor fan, please see pic for more information, i think paul's suggestion maybe ok, alternatively i could leave it as it is?
Let me know
Also i decided to go for the trims for the corners.
Let me know
- 13032009(001).jpg (96.96 KiB) Viewed 2623 times
- manchestertiling
Thanks.
The opposite side i have done the attached. How should i finish? trims or thin breaks? There about 0.5" on each side and about 2.5" on the final row.
please advise.
please advise.
- 19032009.jpg (103.35 KiB) Viewed 2595 times
- under 0.5"
- 19032009(001).jpg (98.1 KiB) Viewed 2595 times
- under 0.5"
- 19032009(002).jpg (90.55 KiB) Viewed 2595 times
- manchestertiling
- manchestertiling
- manchestertiling
Yep I agree it does look good, always satisfying after the grout has gone in, the finishing touch.
Just 1 thing to look out for, clean with only clean water first few times until the grout has completely cured, you may get some effervescence appearing in the form of a white surface coating on the grout, usually do with black grouts. Just keep cleaning with clean water & rinsing, then clean again.
Don't use any cleaning agents as they always have some kind of salt in the ingredients somewhere, whether its sodium this or that & it adds to the problem.
Good work though muscles
Paul
- manchestertiling
