Tile edges
DIY_DisasterMan
Tile edges
Post by DIY_DisasterMan »
Hi there,
I am wondering what the normal practise for using tile edging is. Do you use a spacer between the the tile and the edging strip or do you just fit the edging right up against the tile?
Mooncat
Has thanked: 81 times
Been thanked: 72 times
Post by Mooncat »
I leave a space between the edge of the tile and the extruded plastic corner strip, and fill it with grout later.
manchestertiling
Post by manchestertiling »
Trims are made in a variety of different thicknesses allowing you to seat the curved edge over the tile. Most tiles fixed to the edge of say a window reveal will be cut to fit & therefore it hides the cut edge nicely.
Bevelled edge tiles will need grouting into the trims as the sides thin down to the edges leaving a slight gap.
Paul
[url=http://www.manchestertiling.co.uk]manchester tiling[/url]
manchestertiling
manchestertiling wrote:Trims are made in a variety of different thicknesses allowing you to seat the curved edge over the tile. Most tiles fixed to the edge of say a window reveal will be cut to fit & therefore it hides the cut edge nicely.
I say curved edge, but you can get square
Paul
DIY_DisasterMan
The tiles will be on a toilet waste pipe that I have boxed in
Tiles are square edge and i was thinking of just sitting the trim right up against the tile so that the trim was flush with the tile edge with no space for a grout line as this would be my personal preference. Wasn't aware if should leave space for a grout line so that it gives a waterproof seal between tile and trim?
manchestertiling
Could always silicone inside the curve of the trim, offer them up to the tile & wipe any excess that flows over
Paul
DIY_DisasterMan
The silicone option sounds like a great idea. Thanks
Return to “Tiling Forum”
