- It is currently Mon Apr 14, 2025 4:54 pm
Dampness On Upstairs Chimney Breast - HELP !!!!!!!!!!!!!!!!!
We have had a damp problem in our attic bedroom on the chimney breast for the last seven years, around the time we moved into our 100 year old house. Over this time we have had five different builders who have tried to repair our damp problem by concentrating on the outside chimney area. These repairs have included our entire flashing and felt being renewed and any suspect tiles being replaced. The raggle depth is around 3cm. The chimney itself has been treated with a water repellent coating, the pots have been replaced, and an old gas pot (GS1) taken away. We have spent a lot of money over the years and the last few builders I have spoken to have suggested the only alternative is to decommission the chimney. Two of our downstairs rooms have fire places which feed into the chimney but with only one room operational with a living flame gas fire and flue. The bedroom that has the damp has no vent on the breast, nor are there any others that we can see. We are seriously considering decommissioning the chimney but it will be at a considerable cost and we want to ensure we have considered all the possibilities before we decide to go down this expensive route. Any ideas and advice will be most appreciated
- IMG_4084(small).JPG (24.8 KiB) Viewed 4914 times
- IMG_4085(small).JPG (16.6 KiB) Viewed 4914 times
oilypants
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Post by ultimatehandyman »
Hi and welcome to the forum.
As you say the pots have been replaced, this would mean that the chimney is still open and so any rain water could get in there, but once it is in there it is difficult to get it back out, a vent would certainly help with that problem. Obviously the vent has to be fitted in the chimney where there is no flue from a fire below.
But to be honest it looks like your problem is caused by a leak around the chimney, probably the flashing.
When the flashing was repaired in the past did you remove the plaster from the inside and let it dry before having it replastered?
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
thescruff
leebwk
A selection of pots that my help you from the link below. This will help with the rain fall entering the chimney, then I would look in your loft to see if the pointing is ok. I had a similar problem this year and it was the pointing between the loft and the roof, water penetrating poor mortal and leaking down the inside of the loft wall from the stack. My problem wasn't as bad as this but I do have a very large Inglenook that has a huge fire burning away. I replace the pot with one that has a hood and re pointed the stack between the loft and the roof, problem solved.
Hope this helps.
http://www.stovesonline.co.uk/wood_burn ... serts.html
Hope this helps.
vespa
leaking chimney
Hi the problem is far for unique but can be difficult to resolve. Have a look at http://www.justlead.co.uk here you will find video on chimney DPC and how they work, along with chimney back gutter, flashing etc. This may shed some light on your problem. Good Luck
justlead1
- thescruff
thescruff
justlead1
- thescruff
thescruff
Re: leaking chimney
justlead1 wrote:Hi the problem is far for unique but can be difficult to resolve. Have a look at http://www.justlead.co.uk here you will find video on chimney DPC and how they work, along with chimney back gutter, flashing etc. This may shed some light on your problem. Good Luck
vespa
oilypants
- thescruff
thescruff
- ultimatehandyman
- Site Admin
It is almost impossible to say for definate without seeing it, trying to answer on a forum is difficult. I had a similar problem with a house once and it was the flashing and some re-pointing that required patching up on the chimney.oilypants wrote:Thanks for the feedback guys. However, the last 2 builders have verified the flashing repairs as being of a good standard and I can't believe the builders have it got it wrong
When the builders said that the only way to fix it is by "decommissioning the chimney" the chimney what exactly did they mean, as the flue is in the chimney from the fire downstairs
