Floor tile onto asphalt
Posted: Thu Mar 26, 2009 9:32 pm
by wadge
Is it possible to tile directly onto asphalt? The finish is reasonably hard but there is some very subtle movement.
Posted: Thu Mar 26, 2009 11:36 pm
by manchestertiling
Hi wadge, there is a lot of conflicting information regarding this but most of it is confused with the softer roofing grade asphalt which is intended to be soft so it deforms with temperature changes.
Internal flooring grade asphalt needs to be sound to be used as a suitable substrate for tiling. How much movement do you have?
The surface must be clean and before tiling should be cleaned with a degreaser which itself then should be removed to prevent contamination of the adhesive bonding application.
When laying your tiles, they should be layed on an even bed of a powdered cementitious adhesive.
Asphalt is not the strongest of surfaces and an even bed of tile adhesive should be used. Varying thickness' of adhesive can cause stresses to build up which can result in differential movement and ultimately failure of the tiling.
Alternatively a reinforced decoupling matting system can be used. In this situation a polymer modified adhesive should be used.
Posted: Fri Mar 27, 2009 1:40 am
by Stoday
Use a water based adhesive. An oil based adhesive will soften the asphalt.
Posted: Fri Mar 27, 2009 10:49 am
by Mooncat
A thought, why would anyone have an asphalt floor in a house?
Posted: Fri Mar 27, 2009 1:30 pm
by ultimatehandyman
Mooncat wrote:A thought, why would anyone have an asphalt floor in a house?
Years ago, they used to lay a concrete floor with no dpc under it. Eventually the dampness rises through it and it becomes damp.
You can get asphalt poured onto the concrete, they bring it on a large wagon and heat it up, pour it into metal buckets and then pour it ontop of the concrete and then float it off to a flat finish.
I had a living room and kitchen done a few years back, it certainly stops the damp. You can only really have asphalting done if the house is empty as it fills the place with fumes.
Posted: Fri Mar 27, 2009 7:02 pm
by manchestertiling
My kitchen floor in the last house was exactly how UHM describes, previous occupier did it as a means to stop the damp
Posted: Fri Mar 27, 2009 8:44 pm
by wadge
Think I'll stick with lino then! Was only thinking of tiling on to the asphalt to use up some tiles I have knocking around.
The house will be rented out so probably better in the long term.
Posted: Fri Mar 27, 2009 10:38 pm
by Mooncat
wadge wrote:Think I'll stick with lino then! Was only thinking of tiling on to the asphalt to use up some tiles I have knocking around.
You wouldn't happen to have a couple of Opera border tiles knocking about by any chance? See my recent post, I need 'em!
Posted: Sat Mar 28, 2009 9:16 am
by wadge
Sorry MC, only some B&Q cream floor tiles!
