Floor tile to laminate
hooly
Has thanked: 1 time
Been thanked: 2 times
Post by hooly »
First question, laying a ceramic tile floor, it meets a laminate floor, is it best to lay the edge peice first, and do they fit all sizes, as the floor tile may be slightly higher? then the lam floor
whats the min plywood you can 9mm or 12mm ?
cheers
jdpp
Post by jdpp »
leave 5mm gap and fix door strip between laminate and tiles
12 mm ply
m3 fitter
Tiling Expert
Has thanked: 7 times
Been thanked: 14 times
Post by m3 fitter »
mark where the tolerance is within a t-bar metal threshold, cut your tiles within this, use aquapanel cement board to achieve correct rigidity and or height 12.5mm :-)
Return to “Tiling Forum”
